Torch question! What should these be set at?
Discussion in 'The Garage' started by jjlaughner, Jan 8, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Acyt and oxy settings? anyone?
    We went threw 3 oxy tanks to the one acyt tank /forums/images/graemlins/confused.gif /forums/images/graemlins/ignore.gif
    settings are 40-45 and 5-7 psi /forums/images/graemlins/thinking.gif
    book says 35 and 5 but when you start cutting it pops and goes out, we bumped up the oxygen and it cuts better but still pops and goes out from time to time
    Just checking seeing if I'm doing something wrong? And yes they are strapped on a cart now /forums/images/graemlins/thumb.gif
  2. seawolf15
    seawolf15 Newbie
    Jan 6, 2004
    3
    O2 at 20 to 25psig.
    Acetylene at 4 or 5 psig.
    Light it with the Acetylene then bleed in the O2.
    If your doing cutting set the O2 by looking at the 4 blue flames. They should be about .75 inches long. The best heat is just above the tip of the blue flames.
    Use the O2 bleed lever to blow away the hot metal as you work forward.
    If it doesn’t cut right, then you need a bigger torch or tip.
  3. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    If it pops and blows out make sure that the tip is clean, all the little holes for the oxy and the bigger hole for the acet should be clean and open.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i always run my O2 at 40 and my acetylene at 9, popping out is usually either because of a couple or few of the holes are plugged in tip, or are cutting too close to metal, tanks dont last as long as would like them to, hehe
    good luck
  5. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Is that the tip you're using to cut with?
  6. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I agree with seawolf15 .... /forums/images/graemlins/wink.gif
    for brazing/soldering tip..
    For a cutting torch...7 and 25... /forums/images/graemlins/thinking.gif
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    no thats the heating tip for trying to take off my steering arm! /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif That would be a problem otherwise /forums/images/graemlins/deal.gif
  8. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    I figured as much /forums/images/graemlins/wink.gif
  9. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I'd break-out the cutting torch for that... /forums/images/graemlins/wink.gif
    A brazing torch...is for low heat applications..
  10. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    as others said, popping is generally a dirty tip. buy tip cleaners if it didn't come with them.
    and blowing thru O2 more than acetylene is very, very common. especially if doing alot of cutting. also, rosebud tips are invaluable for heating..
    have fun /forums/images/graemlins/wink.gif as Beavis would say "FIRE, FIRE, FIRE!!!!"
  11. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    If it pops and goes out you need a bigger tip, which shouldn't be a problem for you with the torch pictured, unless you are cutting really big stuff.
    I've seen mechanics and carpenters at work do a little trick that works sometimes. If the tip gets clogged, take a scrap piece of wood(usually a 2x4) and with the torch set like you are going to cut, press the O2 lever all the way and drag the tip across the wood with the tip touching the wood. It will pop and try to go out but if you do it fast enough sometimes it will blow the crap out of the tip. It works for me sometimes and gets you back to cutting instead of messin around with a tip cleaner.
    Just something for those that use a torch to try. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  12. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    LOL...yep...that works.. /forums/images/graemlins/thumb.gif
  13. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/crazy.gif /forums/images/graemlins/smirk.gif I ended up having to do the torch thing, but I got carried away and had to replace the studs and ball joints
    pic
  14. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    You should really have a way to secure those bottles. It's waaaaaaay too easy to tip one of those bottles over in the middle of the floor like that.
  15. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Already taken car of, the second day we had them we had them ona kart to roll in and out of the garage /forums/images/graemlins/thumb.gif
  16. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Hey...play around..that's how I learned..
    BUT..I learned some tips guys that were pretty handy with a HEAT WRENCH!!! /forums/images/graemlins/cool.gif
    I thought we had that covered... /forums/images/graemlins/cool.gif
    I've seen a bottle bounce around a shop before..
    it's NOT a pretty site.. /forums/images/graemlins/eek.gif
  17. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Oxygen I run at 40 minimum
    Acetylene I run at 7, 10 max if using a rosebud.
    Generally popping and going out with a clean tip is caused by not enough fuel for the tip size. Next time that happens turn up the acetylene a little and then re-adjust the oxygen to suit.
    Best thing for a dirty tip is tip cleaners...
    On a cutting tip you have the center oxygen hole (provides the stream of pure oxygen for cutting) and a ring of smaller holes for mixed oxy/fuel. If the tip is clean and adjusted right each of the outer holes will produce a cone of blue flame. It should look like a little crown. Adjust the oxygen until the little blue cones come into sharp focus. Now hit the oxygen bar...the flame should not change much, but you should see a long stream of oxygen. That stream should be quite long (4-6") and also be relatively sharply defined. The more consistant and sharply defined the cleaner it'll cut.
    If you're using acetylene watch the other half of the guage as it gets nearer to empty. At 15 psi on the torch side it'll get unstable. If the torch side is run at anything more than 1/7th the remaining volume it'll get unstable. For that reason you'll see the 'red zone' on the regulator and for the same reason one the other side of the guage reads around 50 psi remianing volume it's time for a refill. You never run an acetylene cylinder completely empty.
    The cylinder is partilly filled with acetone, and you don't want to draw any of that up through the torch head.
    Also you should be running anti flash valves (can't think of the correct term at the moment) at the bottles. This prevents any burn back from reaching the cylinders themselves. They are just little cartridges that screw inline with the torch lines. Basically a glorified 'one way' valve.
    Rene
  18. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    I was under the impression that all new regulators had anti-flash valves on them.
  19. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    They might...our torches at work have separate valves, so I thought it pertinent enough to mention. FWIW our regulators are only 3 years old.
    Rene
  20. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    mine dont... its a cheaper kit froma discount tool company
    Yeah the tip definatly needs cleaned /forums/images/graemlins/thinking.gif
