Torching out spring bushings with a propane torch is possible
Discussion in 'The Garage' started by dremu, Oct 30, 2005.
  1. dremu
    Feb 27, 2000
    15,952
    444
    East of San Francisco
    but just about as slow as drilling them out. It's less work, though, doesn't kill drill bits, and is fun, cuz you get to play with FIRE!
    <Beavis>
    FIRE! FIRE! FIRE!
    </Beavis>
    This does however leave burnt rubber crapp all over my driveway. I hope it rains soon :haha:
    Anyway, it's good news for those of us without oxy/acetylene torches.
    I'm cleaning up my set of 56"s to put into the rear ... still gotta pull the center pin and sandblast them. Thankfully the 52"s I'm gonna use up front are my current rears so they at least have nice new ORD greasable bushings.
    -- A
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    if you use mapp gas its a lil quicker (it burns hotter) but fire is fun aint it? :D
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    yeh fire is fun, my driveway(4 years later) still has a little discoloration. O well, no great loss, the rest of it is trash haha.
  4. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    When i was removing the bushings outta my springs the torch didnt do that good of a job, was kinda slow. On one of the springs i would burn out what i could and air hammer the inner sleeve out. The other spring i put a rotozip on the die grinder and it worked like a drill bit but i could move it around and made quick work of the bushings. The i took a flat air hammer bit and pushed/cut into the outer sleeve, air tools make everything easier :D
  5. diesel4me
    Jul 24, 2003
    17,539
    923
    Massachussetts
    If your lucky..
    A few times I got lucky and removed old spring eye bushings with 2 sockets and a piece of 1/2" threaded rod..much the same way you use 2 sockets to remove a u-joint..bigger one on one side,the smaller one pushes it thru when you tighten the nuts..an air impact gun works the best,but wear goggles,I had one socket grenade on me doing this..washers between the nut and sockets are a good idea..
    Sometimes only the inner sleeve and rubber guts come out--but its easy to chisel the outer shell and cave it in so it will drop out..
    Propane must be awful slow--betcha need 2 bottles!..I tried putting one spring's "eyes" in a roaring wood stove at the junkyard to burn the bushings out--it worked great,but the springs"eye" turned red too!--and we were always leery of it being brittle or weak after that..never broke it though... :crazy:
  6. dremu
    Feb 27, 2000
    15,952
    444
    LOL!
    Actually, no, only took me part of the one bottle ... I got the technique down to heating the bushing up enough where it caught fire, then sitting and watching it burn itself out. Smells nasty, but what the heck. What the ARB abd BAAQMD don't know won't hurt me =)) [Kalifornia joke for the locals!]
    -- A
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Use an oxy acetylene to melt the inner sleeve. By the time that is metaling the rubber bushing is really on fire and melting as well. Let it burn a couple minutes and it will fall out by itself.
  8. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    I just replaced the rubbers that came in a new set of springs with greasable poly bushings. I tried several methods on the first one, and settled on a hole saw a little bigger than the inner sleeve. After the first one, I was able to get it down to 15min per bushing.
  9. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    Drilled holes in the rubber part then used a air hammer to knock the inner sleeve out. Took a flat air hammer bit and caved in the outer sleeve till it fell out. About 7 mins, then cleaned the eye up with a flat head screw driver and drill wire brush
  10. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    thats how I do it
  11. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I remember back when I was a heavy duty-deisel mechanic, I would use oxy acetylen with a cutting head torch, and heat up just the inner sleeve itself. The rubber around it would expand so fast that it would shoot out the inner sleeve out like a rocket :eek1: . I would piont it out into the storage yard, and that sucker would go flying about 200 Ft. It took all of about 2 minutes per bushing.
