Tore off all the unneccessary stuff!
Discussion in 'The Garage' started by BlaKK54Speed, Feb 23, 2007.
  1. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    heres some pics of the truck when i bought it and after i took all the crap off, egr, air, ac stuff. any vacuum lines that were not essential.
    runs way better. especially with the new clutch. i just bought headers the other day they are going in soon! new duals all the way back!
    yipee. getting better every day. getting a welder soon, then comes new sheet metal! yay for no more rust!
  2. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    Looks good. I did the exact same thing. really cleaned things up.
  3. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    what year is your truck? I disconnected and plugged a bunch of stuff on my '84, but I still need to pull it all out and clean it up.
  4. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    85. i havent plugged the exhaust manifold holes yet.... thats why i just got headers, couldnt find anything to plug them with! i got more work to do too.
  5. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    Where did you get that K&N filter thingy from?? I want it!
  6. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    you can pick them up a lot of places. search online. summit has them, jegs too im sure.
    i wanted it on my stang but it wont fit, so there it stays.
  7. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    Do you have a 350? Ill check summit. Thanks! Any problems off roading? I hard K&N + Dirt dont mix very well
  8. dyeager535
    26,975
    The independent test I saw done (I believe it was done by some diesel guys, and the link is on this site in a post somewhere) showed that the K&N let the most particulates through, and that an AC Delco filter was one of the best out there.
    A few other people have mentioned that with dusty/sandy environs, they ended up with particles on the filter base, after the air had passed through a K&N air filter.
    People can make up their own minds, I'm just citing independent tests and results.
  9. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Not to mention all that hot under hood air going in there,
    should have kept the factory cold air intake setup.
  10. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    i've considered the Xtreme top (i think that's what they still call it), but i'd coat it in mud in about 2 seconds. however, it could be a good start for a homebrew cowl induction setup.
    i want to get rid of a bunch of my emissions garbage, too. i'm just not certain how much i can pull and still have the engine run right. i'm no carb expert, even though my first car (87 accord) had one.:o
  11. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    i still have the original stuff, i just snagged this from my buddies truck cause he is sellin it.
    i havent taken it offroading yet. prolly wont use it in much mud either. not too many places to go around here.
    its mainly a good 4x4 for snow/camping/fun stuff.
    i may not even lift it.
    havent really decided yet. im just makin it into a nice truck
  12. dyeager535
    26,975
    Just wondering if you tuned the carburetor after removing the EGR, since it will be running lean at part throttle now?
  13. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I dont really know about our NA engines but on my turbo diesel the K&N are a big no no. A lot of guys in my diesel club were finding sandy dust on their compressor wheels, this obviously is not good!
  14. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    I would personally get rid of that K&N air system and go with a normal K&N open element (just the sides, not the top being opened) and run a pre - filter. that is what I have and i run thru pretty much nuttin but sand and dont have anything in the carb.
  15. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    put the A/C compressor back. you can convert it to onboard air.
  16. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I believe there is a pre-filter available for that set-up.
  17. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I have an 88 :k5: and i wanted to do this to mine but I am scared I would mess up the TBI in some way or another anyone have a list of what I CAN and CAN'T remove?
  18. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I see that you disconnected the charcoal cannister line to the carb. At the very least, you should hook that sucker back up.
  19. dyeager535
    26,975
    If it runs right, there is absolutely NO reason to tempt fate and remove anything.
    The engines are designed to run correctly with all systems in place, removing properly working emissions components only serves to show others that you care nothing about the planet, whatever your own beliefs. (I'm emphasizing that you will only serve to further wacko interests that involve anti-4x4 and motorsports) Which is how locations end up with visual emissions checks, and people end up with vehicles that don't run quite right.
    They don't rob enough power to be concerned with, and if you can't work around the stuff, how do you do anything else on your truck?
    Besides, TBI truck engines are one of the cleanest ones (in regards to underhood clutter of hoses and valves) ever installed by GM.
  20. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Sry I asked the wrong question. I want to remove the AC stuff only cas it takes up space sence I dont have a working AC But the problem is I have working Heat and I dont want to mess that up so the question is. What CAN I remove from the ac stuff without messing up my heat?
