torque and stall converters
Discussion in 'The Garage' started by 85burbanator, Oct 17, 2004.
  1. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    what do they do? what are there benifits? i bought a blazer and it has a 2500 stall converter. i read z3pr's post about his trans woes and there was a post in there about how a trans with low fluid seems like it has a high stall converter. the motor has to wind up a bit to get the vehicle moving. should i replace it or does it actually help?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it helps get the motor in the power band before the truck starts to move.
  3. 85burbanator
    Feb 10, 2003
    577
    lake orion, mi
    ahh. so it stalls the trans till the motor reaches 2500 rpms? thats what i figured. so technically its beneficial to the vehicle. ill be using it mostly for mudboggin and trail riding.
  4. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I think "stall" means that it will stall the transmission on the initial launch until the motor reaches a certain RPM when there is resistance on the truck. The resistance would be your foot on the brake. Am I right?
    I bet the answer is on howstuffworks.com.
    -Chris
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    no, not exactly. stall speed is the fastest the engine can spin when the tranny is stoped in gear. (brakes applied) the higher the stall speed, the "looser" the converter is. a 2500 stall converter may start moving the truck at 1100, where a stock converter (1400-1600 stall) may start moving the truck at 600 rpm. the higher the stall the higher rpm is reached before the truck starts moving.
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    if your running a higher stall converter you will need to be sure to run a fairly large cooler to dissipate all the heat the slippage will create.
  7. 85burbanator
    Feb 10, 2003
    577
    lake orion, mi
    deffinately getting a cooler. i thin i might run it for a while and replace it with a different unit.
