Torque converter bolt holes are not threaded?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Oct 18, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    No!! Just when I get this transmission it, now I'm gonna have to possibly drop it to get the torque converter off. The bolt holes to mount it with the flywheel are not threaded? Is there a special racing stud or a nut that I can use so I won't have to drop it all again?
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i am pretty sure the flex plate should be threaded or you can use a nut and a bolt, id double check, i havent played with an suto for a while /forums/images/graemlins/k5.gif
  3. jmd
    jmd Registered Member
    Oct 25, 2001
    63
    Phoenix, Aridzona
    Where did you buy that winner of a 'verter? /forums/images/graemlins/mad.gif
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    My stock converter had three tabs with holes in it. These would use a short bolt and nut. I put some loctite on the bolts. All is well.
    Good luck.
  5. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    The flex plate will not be threaded, if anything is threaded it's the converter.
    A lot of aftermarket converters (especially those with higher than stock stall speeds) use lock nuts and bolts. It's perfectly fine and it will cut down on the possibility of striped threads (if the converter was threaded).
  6. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    never fear...some converters are threaded and some arent.....just make sure you use loctite on them with nuts and bolts....
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I've had stock 350 converters that didn't have threaded tabs, and as far as locktite goes, I never used it and never had problems.
    But I know better be safe than sorry.
    /forums/images/graemlins/grin.gif
