Torque Converter Bolts
Discussion in 'The Garage' started by 78Suburban, Nov 21, 2005.
What type of loctite should I use on my converter bolts?
  1. no loctite
    5.3%
  2. red loctite (strong hold)
    78.9%
  3. blue loctite (weaker hold)
    15.8%
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I am about to do a motor swap, so this information would be very nice to know. What is the general consensus: red locktite or blue locktite?
    Also the torque specifications would be awsome. I am swapping in a 350 motor to my th400 :bow: :bow:
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I used the red locktight in blue bottle. and I tightened 'em up as tight as I could with a ratchet.
  3. keifer
    keifer Registered Member
    Nov 1, 2005
    16
    MD-Phoenix someday
    red, converter to flexplate is 65ft lbs
  4. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Red Loctite. Converter to flexplate bolts are one of the things you DEFINITELY don't want loosening.
  5. chasone64
    chasone64 Registered Member
    Dec 15, 2004
    88
    Oregon
    Red Loctite - period!!
    I don't like the blue, just my .02$.
  6. Big Truck
    Big Truck 1/2 ton status
    Feb 19, 2005
    129
    hermiston, OR
    Use red on anything you don't want to take apart again, or a long while.
  7. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    it seems that the general consensus is to use red locktite... I suppose that is what I will do. Hope it won't be TOO hard to remove if I do another swap in the future... is it possible to get a torque wrench in there, or do I just use my hands and get it as tight as possible? I surely don't want to have them too loose, and I don't want to strip them either..
