TORQUE CONVERTER! HELP!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CrazeeBush, Dec 21, 2001.
  1. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    Okay, so switching out converters on my buddy's camaro. the old torque converter had threaded holes for the bolts to hold the flywheel and converter together. this new one doesn't have threaded holes, just normal ones. What's up? Do we just use a lock washer and nut to hold them together, or is something not right here? I Need a response ASAP!
    Thanks!
    -BuSH
    '83 K5 Blazer
    '98 Monte Carlo z34
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Yep, you got it. My 68 camaro was the same way.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    u can also use nuts with that nylon stuff on them. I would also put some locktight on there too. make sure you use some grade 8 nuts AND bolts.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
