Torque converter lock up questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueOx, Jan 1, 2003.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I'm the next step of working the bugs out of my TBI swap. I need to know when does the TC lock up. I was driving the Blazer in "DRIVE" (3rd gear) and found the converter to be locking up. I thought the TC locks up in "OVER DRIVE" (4th gear) at crusing speeds only. Am I wrong in all this?
    Charles
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    On my '84, when it had a 700R4, it would lock in 2nd, 3rd, and 4th gears. I've heard not all lock in 2nd, but all lock in 3rd and 4th.
    Now I just take my foot off the pedal and the engine is locked to the wheels. /forums/images/graemlins/smile.gif
  3. eds77k5
    eds77k5 1/2 ton status
    Oct 19, 2001
    383
    washington state
    the torque converter is bolted to the flywheel, so it is spinning at the same speed as the engine, that is the turbine, then ya got the stator and the pump, the other half so to speak, centrifugal force is pumping the fluid and bein redirected and then the transmission turns and then the wheels turn, when you are gettin up to speed the engine is turning faster than the transmission and this "slippage" is what causes poorer fuel performance, when ya get up to speed the transmission almost spins the same as the engine, so you are getting better performance, with a lock up converter they have added a lock up clutch and when the two halves are spinning at the same speed the lock up occurs, thus improving fuel consumption, does that sound right?
  4. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
  5. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    It depends on the switch set-up used in your transmission, there have been variations of switches and wiring used, depending on the application and model year. I had an '85 car model 700R4 that had two switches in the valve body, one switch closed when the transmission was in 3rd or 4th gear to allow lock-up, the second switch was a signal wire to the ECM, it's purpose was to signal the ecm when it was in fourth gear, it wasn't wired into the lock-up circuit at all, there are other variations.
  6. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    Thanks for all the info. I thougt it was only going to lock in 4th gear. When it locked in 3rd gear in thought something was wrong,but now I it's all good
    Thanks again,
    Charles
