Torque converter locker
Discussion in 'The Garage' started by jeff l, Jul 18, 2006.
  1. jeff l
    jeff l 1/2 ton status
    Jun 13, 2006
    104
    New Orleans
    My rebuilt 700r4 doesn't shift right and will not go into OD. The builder said I need a torque locker. So I ordered a TCI brand from Jegs. Has any one installed one with the trans in. If so is this a real envolved job.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    You have to remove the trans to fit a torque converter if that's what you're asking. All 700 have a lock up converter unless they've been modified for racing but this is not a good idea for the street due to the extra heat caused.
    If you're builder has done the job right and you're old converter is ok it's probebly just the TV cable needing to be set right. (see article 101 at www.tvmadeez.com ).
    Make sure your wiring is all conected to the box too.
    Was it ok before you rebuilt the box? Have you had the converter flushed out?
  3. cajunjets
    cajunjets Newbie
    Jul 18, 2006
    Abita
    Are you using the computer controlled distributor or did you switch to the HEI?
    If you are using HEI you might not get any signals from the computer.
    Just wanted to throw that out there for others to add comments.....
  4. cajunjets
    cajunjets Newbie
    Jul 18, 2006
    Abita
    does anyone have a clue????????
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    If he's running a TBI set up he'll have a ecu which uses the later HEI.
    But as some people don't fill out their profile we can't tell!!
  6. jeff l
    Jun 13, 2006
    104
    New Orleans
    I have a carb.
    I don't have a profile b/c this is my first gm truck and when I started coming here the truck was just a shell I really didn't know what it was going to have.:D
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    As you don't have an ECU you'll need a stand alone TCC controller. TCI amongst others sell them. It enables you to lock/unlock your TCC manually which would normally be taken care of by your ECU.
  8. djsblaze
    djsblaze 1/2 ton status
    Jul 7, 2003
    318
    Oklahoma
    Torque Converter Lock-Up switch? I use one on my 700 to keep it from hunting for gears while in OD, but if your OD is already hosed, than Im probably off base here....
  9. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    I think what you ordered was the lock up wiring kit from tci. It is not very hard to install. You pull the pan and filter so you can see the valve body. The instructions will tell you what wires to cut and replace and one or two little pressure switchs. Then you have to wire a ground and a hot wire to the plug on the outside. Mine came with the option of wiring a switch to lock the converter in 3rd or 2nd gear. It also came with a vacuum switch. I tried hooking that up and then bypassed it and through the switch away because it was to eratic. Also make sure your tv cable is adjusted correctly and make sure the point where it connects to the carb linkage has the correct amount of throw.
    Brent
  10. jeff l
    Jun 13, 2006
    104
    New Orleans
    I installed the tci locker and still no OD!!!
    While I had the pan off I could see 1/4'' of space before the tv cable hit the spring, so I adjusted the tv cable so it touched the spring. I hope thats right it seemed to shift better.
  11. sgarrison
    sgarrison 1/2 ton status
    Feb 4, 2005
    148
    Art's Bar and Grill Mt. Pleasant S.
  12. bdozeraz
    Nov 8, 2004
    212
    Phx, Az
    I didn't read your first post right. I thought you said your torque converter wasn't locking up. If the trans won't go into over drive your tv cable is not adjusted right or your shift linkage is not adjusted right. If it is not either of those it is time to take it back to the builder and have him fix it because there is something wrong with the trans. The wiring kit is only for the lockup and has nothing to do with weather it goes into overdrive or not.
    Brent
  13. jeff l
    Jun 13, 2006
    104
    New Orleans
    My shift linkage is right I think b/c i can go in all my gears I even made sure I gave it gas i neutral and it was in neutral, I went to OD and it started to drive
  14. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    There's only one way to set the tv cable. www.tvmadeez.com . read article 101 at top of page.
