Torque converter question
Discussion in 'The Garage' started by neverendingproject, Sep 25, 2006.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    My 4l80e project is coming along nicely and all I have to do now is get a torque converter.
    Im running a 383 so im wondering if I need the low stall for big blocks or a high stall for small blocks.
    What do you think? Still go high stall even though im making big block torque?
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    How do you plan to use the truck, most of the time? Towing? Mud drags? Slow, technical trails? Mall-crawling? Stoplight Gran Prix? Something else?
    What is your cam grind?
  3. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Its going to be a daily driver, but I still want performance (why I went 383). I will do mud and crawling if I can, but DD'ing it is a must. The cam is the GMPP 383HT cam, but its very streetable with good vaccuum and 400+ lb-ft from 2000 on. maxed at 4000 around 460lb-ft.
  4. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    TTT, im looking to get my rig together asap!
  5. dyeager535
    26,982
    191
    Since no one else is adding...
    Don't forget adding input torque to the converter increases the stall speed of a converter. So your 383 with the exact same converter will stall higher than a 350.
    I'd say if doing anything technical, low stall converter is the best. Yes, won't get you off the line fast, but with heat being enemy number 1, a high stall converter on rocks is a bad deal. Yes, you could get away with a high stall around town since you have both OD and lockup, but again once offroad, if your engine RPM is consistently lower than the stall of the converter, you will have major heat issues. Mud that wouldn't be an issue...trails, yes.
