torque converter questions
Discussion in 'The Garage' started by Jonny-K5, Aug 7, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    first one, will a buick converter fit on a chevy tranny? i've got an almost brand new one for my old BOP th350 and i'd like to put in in my chevy th400. i know that 350's and 400's are interchangable as long as they have the same bolt pattern, but not sure about the splines on a BOP and chevy.
    second question: has anyone heard of using a switch pitch converter on their chevy? buick used them in their trannies. i remember reading about a chevy truck that had a custom converter in it that was switch pitch. i think it would be awesome to have the launch of a high stall converter and a cruise rpm of a tight one. what do you guys think of them?
  2. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    TTT, anyone know about this stuff?
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    I think lockup converters made the variable pitch ones obsolete. You can just get a high stall converter with a lockup clutch and get even better gas mileage and lower oil temps than with a variable pitch type. The higher the stall, the better the lockup clutch needs to be. I think these are usually a few to several hundred dollar converters.
    I don't know about the interchangability. You need to know the spline counts and the depth. I know you can't mix lockup and non-lockup stuff.
