Torque converter recomendations
Discussion in 'The Garage' started by 6.2puller, Nov 29, 2006.
  1. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    I have a mildly warmed up TBI 454 in front of a freshly rebuilt TH400 in my V3500 on 37s. Mainly used on the street and towing loads around 10K, sometimes as heavy as 15K. Any recomendations on a torque converter?
  2. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    Depens on what gears you are running, and what kind of rpms you are normally turning. I would recomend a 2,000-2,5000 stall. But if you cruise under 2,500 alot, you will heat up the trans.Dan
  3. 6.2puller
    Jul 8, 2004
    569
    New England
    4.10s Turns pretty low RPM alot I would guess. No tach to say for sure.
  4. DesertDueler2
    Dec 25, 2004
    132
    Chandler, AZ
    Then I would go with a 1500-1800 stall to be safe. It will help get you into the power band better for towing.Dan
  5. 6.2puller
    Jul 8, 2004
    569
    New England
    Any brand recommendations or brands to stay away from?
  6. mattman4x4
    mattman4x4 1/2 ton status
    Feb 16, 2005
    186
    Salisbury MD
    I do not want to hijack this thread, but what dose stall speed mean? say you have a torque converter with a stall speed of 2500 rpm what dose that mean?
    thanks
    Matt
  7. 6.2puller
    Jul 8, 2004
    569
    New England
    the stall speed is the speed at which the torque converter stops slipping, similar to when you fully release the clutch on a manual. Any slower RPM allows slipage and creats lots of heat.
