torque converter
Discussion in 'The Garage' started by adamforsythe, Jul 9, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I just installed my torque converter and tranny last weekend. I was wondering what I would hear if I installed it wrong. I started the truck up a few times and heard no grinding, etc. So am I in the clear?
    Adam
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Well...................................................................................................
    you would hear grinding noises if ya did it wrong Adam,
    have faith in yourself.
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    usually if u did it wrong, as in hooking the flywheel to the flexplate...you wont be able too bolt them up. they will bind together and you wouldn't be able to turn the motor and tranny to line up the bolts for the converter and plate. this is do to not setting the converter right. i got experiance in this one :doah: :doah:
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Also, its not a bad idea to locktight the 3 bolts that connect the converter to the flywheel.
    You'll know if you didn't tighten them good enough because they will loosen up and it'll start knocking REAL loud.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if the converter wasnt engaged in the pump all the way then you would have known it right away
    no worries
    when theres a huge gap between plate or wheel and the converter then i liek to use one or two washers for all three bolts, but dont bottom out the converter snout into the pump though,
    good luck
