torque converter?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, May 28, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What are the symptoms of a bad torque converter.
  2. dyeager535
    26,977
    No movement.
    grinding in park/neutral, or drive alone could also be signs the bearings are failing.
    Seriously, if the converter *fails* you won't be moving, and will likely take the rest of the tranny with it, as metal particles contaminate the whole thing. At best an entire teardown, rebuild is necessary.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah, i agree with dorian, a bad convertor took out my front pump, so i have two choices. rebuild the pump for 35 bucks, and maybe work for a while. or tear down the whole thing and rebuild it.
    well option 3 is get a manual...
    he he, some day...
    grant
