Torque Converters
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChadH82, Oct 4, 2001.
  1. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    I've been doing some research on torque converters and I think I have the basic idea of what they do and how they do it. Now I just need to find who makes good converters for my application. My engine will be pushing 415 ft. lbs. of torque. What stall speed would be good for my blazer? It will see mud and rocks. Let me know if I forgot some info.
    Chad
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    If you do any rockcrawling you'll want a low stall model. What gears/tire size are you running? It will affect stall speed. Is this a SB or BB?
    No more than 2000 rpm IMO.
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Also what Trany do you have......
    C'moe
    Kill Roy was here!
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Your best bet would be to gather up all of your engine specs,axle ratio,tranny, and vehicle weight and call torque converter manufactures .Tell them what you have and what you want to do and they can tell you what you need.This way takes the guessing out of it.
    A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  5. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I would personally run anywhere from a 1400 to a 2000 rpm stall. I'm putting in an auto that's where I'm looking. I have a 3400 stall in my chevelle but that's a different hill of beans
  6. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I called a tranny shop when I was putting in my tranny (TH400) to ask them for a good aftermarket low stall converter and they told me that for low RPM stuff, the best converter I could use was the stock TH400 one. It seems to work good.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Aint Skeered!! </font color=red>
  7. schneggie
    schneggie 1/2 ton status
    Aug 24, 2000
    279
    Colorado Springs, Colo
    I changed my converter recently. I have a 350 with a th350 running 4.56 gears and 35's. I installed a 1800 stalled converter after talking with Stephen from ORD. It works really well, the only problem that I have is getting used to the new position of where the truck takes off. Before when I stepped on the gas the truck would just casually go because the converter would "catch" before the engine hits it prime "torque" point. Now the when the converter gets to it's "catch" point the engine is also at it's prime "torque" point, the results are lots of power and the truck wants to go! So as a result I have been learning how to hit this "torque" point while having one foot on the brake, then holding the gas at that point and letting the brake off very slowly so as not to jump or lunge while rock crawling. The over all end result of where the converter is "catching", the engines prime "torque" point, is awesome! It's like a whole new truck that has the power that you need and when you need it.
    Just my experiences with this.
    Greg
  8. ChadH82
    May 9, 2001
    400
    I will have 39.5's with 4.56 gears and a 383/400 engine/tranny combo.
    Chad
  9. chevyboy24598
    chevyboy24598 1/2 ton status
    Jul 17, 2001
    212
    Va, USA
    I'm running a 2400-2800 stall on my truck. 350/350/np203 and 4.56 gears on 33s
    Rust=Good
    <a target="_blank" href=http://www.bodatious.com> bodatious </a>
    <a target="_blank" href=http://www.mudboggingfun.homestead.com> my site </a>
  10. ChadH82
    May 9, 2001
    400
    Does anyone have a preference on a specific brand or company building them?
    Chad
