torque convertor, deezel vs gas
Discussion in '1982-Present GM Diesel' started by 55Willy, Sep 5, 2005.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    is the only thing different between a diesel th400 and a gas th400 is the torque convertor?
  2. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,038
    1,106
    Dallas
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    does the same hold true for a th350 and 700r4???
  4. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    yup ;)
  5. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    What is the difference? stall speed?
  6. 6.2 man
    6.2 man 1/2 ton status
    636
    Curtis , WA
    Diesel torque converters have a lower RPM range . If swapping transmissions you need to swap governers . The Diesel one has a lower RPM for shifts .
  7. 86dieselburb
    86dieselburb 1/2 ton status
    Oct 20, 2004
    219
    Crestline, CA
    I believe the shift modulator is different also. I have a built gas turbo 400 in my 6.2 burb. It works, just shifts at higher RPMs than the diesel 400 normally would. Mine seems to shift out of first at about 35mph and into 3rd at 55mph. I kinda like this for normal driving because you get up to speed faster, but it sucks if speed limits are 25-35, never gets a chance to get out of first.
  8. BowtieBlazer
    Jul 15, 2001
    2,462
    just installed a 350 in place of a 6.2 and it looks like the TQ bolt holes dont line up to a 350 flywheel.
    This is on a 700r4
  9. diesel4me
    Jul 24, 2003
    17,566
    942
    Massachussetts
    dual bolt pattern??
    Perhaps the flexplate has 2 sets of bolt holes?--most GM's have two,one set fits the TH350 and the other fits the TH400 and others..never looked at my 6.2 convertor,so you could be right!..
    86 DieselBurb--I think the modulators might be listed as "different" in the parts catologs,but are basically the same thing as a gas tranny uses--the spring inside MIGHT be a hair less or more tension..its likely the GOVENOR in your tranny being calibrated for a gas engine thats causing your "late" shifts..a modulator "'adjustment" screw only varies the speed of the shift about 5-10 mph and the "firmness" of the shift from one end of its adjusment range to the other...
    I ran the vacuum directly from the vacuum pump to the modulator on my TH400 in my 82 K20--the "VRV" valve (Vaccum regulator valve) was shot on my truck,it regulates the amount of vacuum sent to the modulator,so it mimics the vacuum a gas motor has(a diesel with a vacuum pump makes vacuum at ALL speeds,and INCREASES as the RPM goes up--just the opposite of a gas motor,and that valve bleeds off the vacuum to the modulator as rpm increases)...
    I had to screw the adjustment screw on the modulator IN all the way to compensate for the excessive vacuum,(at the advice of an experienced tranny rebuilder,this is what he does in cases like mine)--and it still shifts a bit too soon and soft for my liking--I'd replace the valve,but GM no longer sell it,and junkyards wont "break up" a running motor,or they are junk like mine already :doah: ..I'm hoping it wont shorten the life of my tranny--I plowed 25 bad storms last winter,and so far its holding up fine--hope it stays that way! :crazy:
  10. 6.2 man
    636
    Curtis , WA
    They should line up my tranny came out of a gas 350 and thats all I changed was the govenor
  11. BowtieBlazer
    Jul 15, 2001
    2,462
    Alright maybe its a year to year difference thing. The tranny is in a 1984 model c-10 with a 6.2 it has 6 bolt holes in the TQ convertor(700r4)..... the block is a rebuilt 4 bolt main out of a 90 model 3/4 ton.....was in front of a th400....thinking about it now I bet thats where the difference is, if i remember right though that was a 6 bolt hole flywheel as well :thinking:
  12. diesel4me
    Jul 24, 2003
    17,566
    942
    Massachussetts
    6 bolt converters?
    Only 6 bolt torque converter I ran into on a GM was in a chevy van that had a 292 straight six in it,I think it was a TH350,but I'm not sure(long time ago!)..We bolted it to a 3 bolt flexplate ,the three holes lined up..just left the other 3 empty!--not sure if you can do this in your case.. :crazy:
  13. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    My th400 has 6 bolts as does my 4l80...both diesel units.
  14. 6.2 man
    636
    Curtis , WA
    All GM converters had 6 bolts remans have 3 go figure ????
  15. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    not true, you can get remans with 3 and 6. it depends on the application. almost every diesel has 6 bolts while almost every gas has 3. there are a few that crossover, but not many.
  16. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    so whats the lock up rpm for a diesel convertor? i may just run it if it will match my engine, probably not though.
  17. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a diesel converter usually stalls around 1000-1200. the lowest gas converter stalls around 1400.
  18. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    There are some gas TC that lock up at 1250 and the diesels are 950 to 1100.
    All diesel TC have six bolts.
    You need to change the governor and the TC that is all.
    I ahve doen some of those swaps and I have talked to tranny builders, some claimed it was more and then I started asking them questions, specific questions about what and why and I explained what you would only need those 2 items and they eneded up saying oh well you could do it that way but we have different part numbers for GAS and DIESEL.
    :doah:
  19. aj johnson
    aj johnson 1/2 ton status
    Nov 2, 2004
    232
    Idaho Falls, Idaho
    question... I'm using a caddy 472 engine with it's early torque curve, and using a TH400 out of a M1008. which parts should I switch to get the best economy? I have both the caddy 400 and convertor, as well as the diesel one.
