Torque Convertor Install issues
Discussion in 'The Garage' started by jekquistk5, Feb 22, 2006.
  1. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,008
    841
    Pinckney, MI
    I can not seem to get my new convertor to slide right into the tranny. I replaced the seal and tried wiggling and turning but with no avail. Heres the pics Am I anywhere close. It just seems to far
  2. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    try standing the transmission on its tail end and spinning the torque convertor. thats how ive always put them on, we just spin them until they make three drops and then its on all the way, its a trick my dad showed me.
  3. jekquistk5
    Jan 18, 2004
    11,008
    841
    Pinckney, MI
    I'll try that... but wont all the fluid that I put into the convertor drain into the tranny.
  4. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    actually the fluid has never leaked out on me. maybe a little bit but I just slid it on the shaft like you have it and then stood it up and it didnt leak.
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    in the second pic, it doesn't look like it is square to teh tranny. may have to move it around a bit more.
    are you sure its a 700r4 converter and not a th350c converter, they are very close in apperance , but the hub that fits into the pump is different.
  6. jekquistk5
    Jan 18, 2004
    11,008
    841
    Pinckney, MI
    I gave the guy the exact numbers of the convertor.. and thats what he handed me. It looks the same, I'll have to check the spines. Its a reman so I have no clue. We shall see
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    It could be it just needs to catch just right, but also be aware that the 700 used different input splines over the years. I believe the early 82-82 used a smaller input shaft than the later ones (going from memory so I could be wrong)
  8. jekquistk5
    Jan 18, 2004
    11,008
    841
    Pinckney, MI
    I told the guy the exact year of my truck, that it was a 700r4, and all the numbers and even handed him the old one. He said Yup your good to go. So I hope it just needs some more finese. But its snowing out today :doah: . It was almost 50 yesterday too. I hate Michigan weather
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    id make sure you have a 30 spline converter and not a 27 spline converter. you need to count the second set of splines in the converter. the 27 spline input shafts were on 82-early 84, then changed to 30 mid 84.
  10. jekquistk5
    Jan 18, 2004
    11,008
    841
    Pinckney, MI
    Its all the way on now. It just needed to take more time, and not get frustrated. I went there stood it up on the tailshaft and turned and lifted up a little and then click, click it dropped right in.
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    :waytogo: :waytogo:
  12. jekquistk5
    Jan 18, 2004
    11,008
    841
    Pinckney, MI
    Yeah I just needed to lift up on it rather then rattle it. Standing it up on the tailshaft helped out soo much
