Torque Convertor with Big Tires/Power?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BorregoK5, Oct 16, 2001.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'm in the market for a new torque convertor and want to find out what people are running with success. My stock convertor contributed to the overheating and destruction of my th350 this last weekend so I'm looking at a few RV style, heat reducing convertors from 1400 to 1600 rpm. Anyone running one of these with 36" + tires and above 4.11 gearing on a high displacement small block?
    "I'm looking for a Dana60 Front Axle.." I asked, "You wish! HAHA" the wrecker replied! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I had probs w/ my tranny overheating (see pics from Blazer Fest) because of the 36" tires and 3.73 gears. I installed a B&amp;M cooler (the bigest w/ a install kit) and have not had a prob sence.
    I would install a cooler first (if you dont' have one already) than think about a torque converter.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    my trannie has a stock cooler i've got 3.73s and i'm gettin 36 will my trannie be ok?
    donate to the "Build Scott's Suburban Foundation"
    scott,
    1989 GMC suburban 3/4t 4" lift soon to be rollin on 36" swampers, tbi350, th350, np241
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    On the torque converter I was looking at a TCI Truckmaster. It is $230 from PAW. They say it will lower temp 20deg. All the B&amp;M ones (that I have seen) are higher than stock stall (this one is lower I think).
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Have you seen the pics from the Blazer Fest See it Here
  6. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I was nearly on fire when mine overheated this last saturday. I didn't have an external tranny cooler then, just the stock radiator one. My tranny fried and boiled the ATF, shooting it out the dipstick and all over the exhaust manifol (probably sounds familiar, eh). Anyhow, the tranny is shot and I'm getting a rebuild with an rv/towing style shift kit, mostly to increase the pressure on the plates and reduce heat generating slippage. I already bought an external B&amp;M tranny cooler with the torque convertor being the last heat generating item. I saw the truck one you speak of, but I'm looking at going with a cam which requires a higher rather than lower stall. I may go with the flatter torque curve from a less radical cam and get the lower stall truck convertor from TCI. I was kinda hoping someone has already ran one. Thanks for posting with the tire size and gear ratio - I was running 33's on 3.07's when mine blew!
