Torque for leaf spring to axle u-bolts??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Waxer, Jun 11, 2002.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    It's been a while and I was wondering if anyone knew offhand what the torque setting was for these. I installed my front zero rates yesterday with new u-bolts front/rear from ORD. I currently have the front torqued down to 90ft lbs. but I'm curious as to what the correct torque setting is. Thanks in advance.
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I think it's more like 125-140...90 seems a bit low.
    Rene
  3. 84Sierra
    84Sierra Registered Member
    Jun 1, 2001
    43
    Cleveland
    I think it's 150. I'll check when I get home tonight.
  4. jberg62
    jberg62 1/2 ton status
    May 7, 2001
    104
    Long Island,NY
    I too would say 150 ft. lbs.
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    My directions called for 90-110...
  6. Waxer
    1,857
    Long Beach, CA.
    Thats what came to mind when I installed my new suspension from ORD over a year ago. Somewhere around 90 or just a little bit higher.
  7. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    It's definately 150lb.
    Boss
  8. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    The Chevy manual calls for 140.
  9. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Will over tightening the U bolts cause problems?
    I just tightened mine down as much as I could. Will this cause any issues for me?
    Now, over tightning the leaf spring eye bolts I can see causing problems, but U-bolts?
    Thomas.
  10. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    From the Chevy service manual... Tighten diagonally opposite nuts to 40- 50 ft. lbs. Then tighten all nuts as shown to specifacations which for a C- K truck is 140 ft lbs. Also the caption to the pic says... NOTE: "U" BOLTS MUST BE LOCATED AROUND THE AXLE TUBE SO THE LEGS PASS THE SPRING SEAT WITHIN .060. And it's all caps like I typed it. /forums/images/icons/shocked.gif
  11. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    If you over tighten theonly problem that could arise is breaking your U-bolts, and you would notice this immediatly! You could possibly crush your spring perches but this is unlikely, it would also limit the amountthat your springs could flex but this would be marginal.
  12. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Mine are IR244 tight.
