torque numbers for the 6.2 J code
Discussion in '1982-Present GM Diesel' started by tRustyK5, Dec 11, 2002.
  1. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Humor me...I'm curious and can't find it anywhere/forums/images/graemlins/mad.gif
    My Chiltons shows 140hp and 240 tq at 2000 rpm...which doesn't exactly jive with the spec's page (J-code=151 hp)
    so how much torque does this thing put out??
    Rene
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    It depends on the year (fuel injection pump and head changes), but the 155 hp J model was rated at 285 lb-ft of torque.
    The early model 130 hp C motor produced 130 hp and 240 lb-ft of torque, from the factory.
    Casey
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    So where could a guy find these spec's?? Yahoo searches get me nowhere/forums/images/graemlins/mad.gif Chiltons in nearly useless and the Haynes diesel repair manual has nothing...
    Rene
  4. arveetek
    Mar 1, 2002
    722
    I got my information from www.thedieselpage.com from a 1997 article published there showing various torque and hp specs.
    I'm not sure where to tell you find that exact of information for your particular engine. You might have to find some GM shop manuals and see if they can break it down.
    Probably the easiest thing to do is find the date code on your block, to see what year it is. Then get the numbers off the heads, and then go to GM with that information to tell you for sure what you've got. The 6.2L was manufactured up until 1993, and each year had a little more power (from the factory) than the first.
    Casey
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    FWIW
    HMMWVs are spec'd:
    6.2 150HP @3600 260 FtLbs @2000
    6.5 160HP @3400 285 FtLbs @2000
  6. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    These are figures from my GM manual that covers '82-88 LL4 and LH6 motors.
    Highest gross HP was 1988 LL4 with 155hp/270tq.
    Highest net HP was 1988 LL4 with dual exhaust, 148/264@2200rpm. Single exhaust was 143/262@2200.
    Lowest net was 1988 LH6 single exhaust, 126hp/240tq@2200rpm.
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    So what does your book say about an 85 J-code 6.2? Manual tranny and 3" single exhaust...
    It was from a K20 if that helps any.
    Rene
  8. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    It only lists dual exhaust for '82-87. 1985 LL4(should be "J"code) as follows:
    Gross: 155hp/250tq@2000
    Net: 148hp/246tq@2000 rpm.
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Thanks Dan!
    rene
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    A j-code from an 89 suburban running duals would be???
    -Jeremy
    "DEEZEL /forums/images/graemlins/burb.gif"
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
  12. OAKES
    OAKES Registered Member
    Mar 6, 2003
    7
    ALBERTA, CANADA
    LOOKING FOR A GOOD WAY TO INCREASE HORSEPOWER AND TORQUE WITHOUT BREAKING MY POCKETBOOK , I HAVE A 6.2L IN A 86 K-10
  13. OAKES
    Mar 6, 2003
    7
    ALBERTA, CANADA
    never mind i found this info on about a half dozen other descusions
