torque on 5/8 u bolts
Discussion in 'The Garage' started by ryan22re, Sep 13, 2005.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    what should i torque 5/8 u bolts to? i was thinking 100 ft-lbs. forgot to ask the guys at the spring shop.
    ryan
  2. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    95-130 ft-lbs in my Tuff Country spring install manual.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    110 in the Skyjacker manual
  4. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Ive done this a few times... I just go crazy with a big mutha of an impact wrench!!! Ive had 'em loosen up on me once...Wasnt pretty. Broke off the centering pin that holds the leaves together and the axle slid back and put the wheel into the fender. Luckilly I had some mud flaps on at the time so it didnt shred my tire while on the freeway!! Ever since then I make sure they are tight as hell!!! Had to tow it home about 50 miles. Double check and make sure those U-Bolts are tight!!!!
  5. MarcS
    Oct 4, 2002
    515
    NJ
    Oh yeah, a good point. Re-torque them after putting some milage on it.
  6. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Yeah, check at least every tank of gas. Mine kept torquing down for about 5,000 miles while they stretched and they stay at 110 comfortably now, but I still check every oil change.
  7. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I know that should be done after changing suspension parts, but why is it that when you buy a new vehicle you don't have to keep retorquing the ubolts. :confused:
  8. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    why dont you have to break in the engine or the diffs? i know that nissan has a break in for their diffs, but never heard of any other manufacturer saying that.
    ryan
  9. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Well I would still think a new vehicle would need to break in the engine. I would treat it as such. The diffs... I dunno. Dont when you rebuild an axle or chang the ring and pinion just drive it around for a bit then let it cool and be done?? My parents just bought a new vehicle and they have to bring it back to dealer after 1000 miles to be checked over. Maybe that has something to do with breaking in stuff...
