torque on aluminum manifold?
Discussion in 'The Garage' started by lazerus, Feb 28, 2003.
  1. lazerus
    lazerus Registered Member
    May 13, 2002
    51
    north texas
    howdy fellows,
    do you torque aluminum intake manifolds the same amount as cast iron? we are talkin chevy small block with edelbrock performer.
    thanks!
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I do with no problems. Around 35 foot pounds or so. /forums/images/graemlins/grin.gif
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    im pretty sure edelbrocks spec is only 15 lbs or so, its not very much at all.
  4. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    do them till they r tight and then about another 1/2-3/4 of a turn. and ALWAYS start in the middle and work your way out on an aluminum intake. goo luck
    NITRO
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i would go no more than 25, it;s not like your holding down the pistons or something. it just lets in air. as long as it seats and seals correct you should be ok. i used 14-lbs on the vortec and they only use 8 bolts, none on the center of the manifold. that was over 2yrs ago.
    ARQ.
