Torque question?
Discussion in 'The Garage' started by JUNIOR-K5, Aug 23, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    I just installed a shackle flip from diy 4x great product kert. Question is what should I torque rear shackles to I put them at 45lbs. is that good or not enough. Thanks
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Which bolts are you talking about? If you mean the bolts that hold the brackets to the frame then what diameter of bolt is being used?
  3. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    I mean the rear shackles that hold the springs where bushings go.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Oh ok, i think those go to like 80 lbs. They are 9/16" IIRC?
  5. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    Cool thanks how about the front shackles would they also go at 80lbs.
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Depends on bolt size. GM used two different size bolts.
  7. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Now this is just me but I use nylocks on all my bushing bolts and tighten them down to just after snug. I do this to prevent binding. You will have to replace your bushings more often (like every two or three years) or at least I have had too.
