Torque rating for R&P bolts to carrier?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Boss, Feb 21, 2002.
  1. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Anbody know how much the torque rating is for the Ring bolts to the carrier? (this is for a Dana 60 front). Putting the ARB in this weekend and that would help ;) Oh, what about torque specs for the Bearing caps too? I know to use LocTite Red. I'm guessing like 100lbs for the bearing caps and maybe 80 or so for the ring bolts???
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Go to www.ring-pinion.com (Randy's Ring and Pinion). They have an on-line tech library and you can download a .pdf file with installation instructions and all of the specs you need for all of the common axles.
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    ring gear to carrier 110 foot pounds and the caps are 80 foot pounds. Good luck with the installation.
  4. Boss
    2,550
    Maryland
    Thanks guys.. :)
    Boss
