Torque spec for body mount bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RiceDaddy, Feb 6, 2002.
  1. RiceDaddy
    RiceDaddy Registered Member
    Feb 3, 2002
    79
    Tejas
    Does anyone know the torque spec for the body mount bolts on a 1980 K5? I've done a search on this forum and found quite a few threads on this topic, but I couldn't find the torque spec. BTW.. this job does take it out of you. PITA.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    65-70 ft lbs. I used poly bushings and the front ones moved a little so I torqued them to about 90 ft pounds..
  3. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    when I did mine i was told between 85 and 100 pounds, i did mine to 90 pounds...
    -matt
    <font color=purple> "Stuff's only good for 2 things, degreasing engines and killing brain cells"</font color=purple>
    <a target="_blank" href=http://www.geocities.com/shaggyk5>www.geocities.com/shaggyk5</a>
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    I remember the instructions from Energy Suspension for the body mounts listed the bolts to be torqued to 85 ft. lbs., but that was the regular cab truck that I was working on at that time. (a '79 K20)
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  5. RiceDaddy
    Feb 3, 2002
    79
    Tejas
    Thanks Guys! I'll finish torquing them up tonight.
