Torque spec on poly body mounts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JST12, May 14, 2001.
  1. JST12
    JST12 1/2 ton status
    Aug 29, 2000
    192
    Garland, TX
    Does anyone have the torque spec for the polyurethane body mounts? I installed the Energy kit a while ago and left the bolts a little loose so the body could settle while I worked on the rest of the vehicle. I now have lost my instructions and don't know the torque to give these guys. Energy will not reply to my inquiries. Please help!
    Thanks,
    JT
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I had Energy Susp. body mounts too once. I lost the instructions but if I remember, I think they said to torque the bolts down to 85 ft. lbs. Not real sure, but think it somewhere around that range.
    When In Doubt, Whip It Out!
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I don't know the specs, but I do know that you DONOT want to over tighten poly! poly cannot and will not flex if it is squezzed too tight. So what I did was use nuts with nylon inserts on my mounting bolts and then tighten the mount just until the washers/shims can no longer be rotated or moved. I did this over 5yrs ago and have had 0 issues......
    hope this helps
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  4. dyeager535
    26,982
    191
    Do the mounts have the "sleeves" that go in the center where the bolt goes? I just did a set on my car, and realized that I *can't* overtighten them, because the "sleeve" hits the washer on both ends before the mount can crush. Very good setup.
    I know some people won't like this idea, but I lubed the heck out of the bolts with marine lube, to keep the exposed threads, and bolt shank, from rusting, so if I ever need to loosen them again, it will be easier than it was last time : )
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
