torque spec
Discussion in 'The Garage' started by 87blues, Sep 13, 2005.
  1. 87blues
    87blues Registered Member
    Jun 2, 2005
    24
    Virginia
    Anybody know what the torque spec for an 87 Jimmy K5 transmission pan bolt is?
  2. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    My Chiltons manual says 12 ft-lbs ina criss-cross pattern.
  3. 87blues
    Jun 2, 2005
    24
    Virginia
    Thank you. That works for me.
  4. dyeager535
    26,979
    Don't try to use a ft-lbs torque wrench unless you have one that is designed for only the very small torque amounts. (if they make such a thing)
    An in-lbs wrench would probably do the job. From my experience, a ft-lbs wrench is nowhere near accurate at the low end and will easily strip aluminum threads.
    12ft-lbs is nothing, I use a socket wrench and grasp it around the head, and tighten that way. Not enough leverage to do harm if you don't go ape on it.
  5. 87blues
    Jun 2, 2005
    24
    Virginia
    I found that out the hardway yesterday. Tried to used the ft-lb torque wrench and it was not popping at the 12 ft-lbs. So I gave it up and did it with a regular ratchet and believe I did not over tighten them.
