Torque Specs For 14 FF Rear Diff
Discussion in 'The Garage' started by trukman1, Mar 22, 2002.
  1. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Can anyone tell me the torque specs for the inner and outer bearing nuts and axle flange bolts? Thanks, Gary
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If memory serves me right, inner nut 50 lbs. while turning drum then back off til loose then retighten until no play, (not loose, not tight) then outer nut 50 lbs. Axle bolts 115 lbs.
  3. trukman1
    Mar 5, 2002
    129
    Ohio
    Thanks for the info...now I'm headed back to the garage (I set a slight preload but the truck is still on stands so now is the time to correct it.) Thanks again, Gary
