Torque Specs for Body Mount Bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79Guy, Jan 7, 2001.
  1. 79Guy
    79Guy 1/2 ton status
    Jul 8, 2000
    178
    Southeastern VA
    Hello All,
    I'm finally putting the rig back together after about 8 weeks of downtime. I got started, then needed a part, it snowed, it was cold .....
    Anyway, I've put in new bushings and the ORD 1" body lift.
    Was looking for the torque specs for the body mount bolts.
    Thanks for any help,
    '79 Guy
    1 Blazer - 7 Children
    <A target="_blank" HREF=http://79guy.coloradok5.com>http://79guy.coloradok5.com</A>
  2. 82K5
    82K5 1/2 ton status
    191
    kansas city
    #1 is 55 ft. lb.
    #2 is 45
    #3 is 35
    #4 is 35
    #1 is at the very front and they go back to the rear where the one closest to the rear is #4.
    this info came out of a 1982 chevy light duty truck 10-30 series shop manual
    Phil from K.C.
    1982 K5 Blazer Silverado
    Built in Flint, Michigan-January 1982
    It has one of the very first 700R4 transmissions ever built.
  3. 79Guy
    Jul 8, 2000
    178
    Southeastern VA
    Thanks Phil from KC.
    I guess the 75lbs that I guessed at was a little much ;-(
    '79 Guy
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Whoops, I better go loosen mine. They were loose, so I broke out the impact, put it on 4, and hit them all.
    They looked a little squished come to think of it...
    -- Mike
