Torque Specs for front 10 bolt?
Discussion in 'The Garage' started by johnathan, Sep 4, 2006.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I've done some searching and found 45 ft lbs. (spindle) 60 ft lbs.(bearing caps)Are these correct?, and I also need the ring gear bolts torque specs.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Carrier caps are 55-60ft. lbs., ring gear bolts are 50ft. lbs., spindle to knuckle 45ft. lbs.
  3. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    :D Thanks!
