Torque Specs for GM Corp 12 Bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mike80K5, May 31, 2001.
  1. Mike80K5
    Mike80K5 Newbie
    May 31, 2001
    Atlanta
    I got a chrome diff cover from LMC for my rear differential, but it doesn't have the torque specs. Anyone know what they should be?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Those covers for differentials are to be torqued around 15 ft. lbs.
    When In Doubt, Whip It Out!
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I'm takin a stab at this but around 20lb-ft should be good.
    I would recomend loc-tite too.
    A buddy of mine just put one of these covers on and for some reason the bolts backed off and the lube leaked out and ... well lets just say he is now putting in another axle.
    See ya
    my truck's not dirty, it's earth tone paint
  4. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i dunno what the exact torque number is. i just put it down till they are tight enough so it wont leak and dosen't squish the gasket. in the haynes manule it sez to tighten all the bolts securely. hope this helps
    Going nowhere everybody is a Moto Psycho
    Got my wheels in motion and i got a path to beat
  5. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    My Haynes manual says "clean the gasket mating surfaces of the housing and plate, apply thin layer of RTV, align the bolt holes and press into place, tighten bolts SECURELY" !! Well no sh!t. No torque values listed in any of the tables either. Sometimes Haynes can be the PAINS...lol.
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Thats why I use original GM parts catalogs. They have every listing for torque specs anybody could ever ask for!!! Beware, these catalogs are not cheap, either!!!!!!!!!! [​IMG]
  7. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Most don't go to the trouble of using a torque whench !
    But since you asked I say 25-35 lbs./ft. would work.
    Good luck
  8. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I just put a new cover on my Dana 44 front axle and my shop manual said 35 foot pounds for it. I'm pretty sure the rear axle would be close to the same thing. 30-35 would be safe.
    '73 K5
    Chevy good...Ford bad
  9. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I got one of these covers on the 12 bolt of my 87. The truck came with it on, and I didn't pay much attention to it. However, the first time on the rocks, the lip on the thing was kaput. If you're gonna beat your rig, there's really no reason to have a chrome cover. Just figured I'd share
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    My GM shop manual says 20 foot pounds. It is the same for all GM corp axles
    The Dana axles torque to 35 foot pounds.
