torque specs' for poly bushings & greasable bolts?
Discussion in 'OffRoad Design' started by solowookie, Apr 23, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    torque specs\' for poly bushings & greasable bolts?
    torque specs' for poly bushings & greasable bolts???
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Re: torque specs\' for poly bushings & greasable bolts?
    For the front shackles it is something like 65 ft/lbs. I think. When I installed mine, I didn't have the specs, and I didn't have access to CK5, so I just tightened those bad boys down real tight. When I get home, I am going to loosen them and retorque them, becuase I am probably loosing flex, or at least causing undue friction.
  3. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    can anybody confirm the torque setting here?
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The front shackles tighten to 50 ft lb. all the rest can go to 75 or 80.
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    thanks Stephen...
