torque specs needed for suspension. ***new question***
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Sep 11, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    ok, what are the specs for the bolts in the front spring eyes and the bolt at the top of the shackle? i just put in a set of hill shackles and need to know the specs on these bolts.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Re: torque specs needed for suspension.
    This is what Mr. Haynes tells me:
    Front suspension -
    "spring front eye bolt.....90ft lbs."
    "spring rear eye bolt ....50ft lbs."
    "spring-to-rear shackle nut.......50ft lbs."
    That "spring-to-rear shackle nut" description doesn't make much sense to me, but that's what it says.
    Hope this helps.
  3. muddysub
    Jun 23, 2001
    10,451
    489
    yeah i was like "huh?" but i'll get it figgered out
    anyone else?
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I seem to remember hearing that you want alot less torque than that, but I can't give you a number. The tighter they are, the more it will limit flex. You need the balance between staying tightened and loose enough that it doesn't bind the hell out of the bushings. that wasn't helpful, was it? /forums/images/icons/tongue.gif /forums/images/icons/crazy.gif </font color>
  5. muddysub
    Jun 23, 2001
    10,451
    489
    well i tightened the front eye bolts, i got to 80 ft/lbs and that looked too tight to be honest. the mount for the spring is pinching the bushing, that's bad right? the hangers are angled inward and actually kinda poking the bushings. i should loosten them huh?
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've got all of mine at around 50 pounds and it seems to works well.
  7. muddysub
    Jun 23, 2001
    10,451
    489
    hmmm. i'll loosten mine. /forums/images/icons/crazy.gif
  8. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I usually don't torque down poly bushings. I just tighten until they feel right. /forums/images/icons/blush.gif
  9. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I don't know a specific torque spec. either. I tighten it until it "feels right."
    Will
