Torque Specs needed
Discussion in 'The Garage' started by TxK5Blazer, Oct 16, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I am putting on a shackle flip and 4" front springs tommorow and need to know a few things.
    Ubolts front torque-?
    Ubolts rear torque-?
    tie rod ends torque-?
    drag link ends torque-?
    I think this is it if not someone please remind me thanks ....Jason
  2. paveslave
    paveslave Registered Member
    Oct 11, 2003
    36
    Crestview, FL
    All I got is specs for 88 and up but yours has the same drivetrain so here they are: Front u-bolts 150 ft.lbs., Rear bolts facing up-125 ft.lbs. bolts facing down-147 ft.lbs., Tie rod end stud nuts 45 ft.lbs. / clamp bolts 14 ft.lbs., connecting rod (from pitman arm to knuckle on left hub) stud nut 89 ft.lbs. / clamp bolts 40 ft.lbs.. As I said this came from an 88 to 98 manual so use the info as you will.
