Torque specs on 14 bolt FF?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tRustyK5, Dec 8, 2000.
  1. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    I'm going to weld the spider gears in my 14 bolt tonight at work. I can't find torque specs in my manual for the ring gear bolts or the bearing cap bolts. Does anyone know what the correct specs are for these?
    Rene
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Ring and Pinion - 120 Ft Lbs
    Bearing cap - 135 Ft Lbs
    So ya making a Lincoln Locker out of the 14 bolt???
    Hope this helps.
  3. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Yeah. I figure if its too obnoxious I can always put a Detroit in it later.[​IMG]
    Rene
  4. Wheels
    Aug 18, 2000
    638
    What was involved in putting a 14 bolt in your rig?? Looking at replacing the 12-bolt, axle loosing, limited slip, 3.07 geared, narrower than the front, in mine.
  5. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    It just bolted right in, my 14 was out of a 3/4 ton. I got the T-case and tranny, front-end and driveshafts all from the same guy. If your just swapping in the 14 you might have to change your driveshaft. I'm pretty sure the 14 bolt uses larger u-joints and the overall length from the T-case to the pinion may be a little different, although I'm not sure if you'd need to shorten your shaft or not.
    I was fortunate to find a complete drivetrain that had already been swapped into a Blazer once so for me it was a no-brainer.
    By the way the 14 bolt FF is still narrower than the front.
    Rene
