torque specs on a 14ff
Discussion in 'The Garage' started by spoolnaround, Sep 23, 2002.
  1. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I did a search but to no avail. What are the torque specs for the main caps and the ring gear?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Main caps are "differential bearing caps" and should be torqued to 135 ft. lbs.
    Ring gear bolts should be torqued to 120 ft. lbs.
