Torque specs on HP engine mounts?
Discussion in 'OffRoad Design' started by Burt4x4, Dec 15, 2004.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey Stephen, what is the torque spec on the center eye bolt for your HP engine mounts? If no specs then do I just tighten it super tight or what?
    Thanks for your time
    Burt
  2. Burt4x4
    6,854
  3. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    We never get out the torque wrench for those. Just tighten them up and go. They are fairly good sized bolts and you should have nylock nuts with them. You should be able to feel that they are tight enough.
    No 5' cheaters needed.
  4. Burt4x4
    6,854
    ThankYOU, I was thinking that was my answer but just wanted to make sure...I am almost ready to fire up my 454 for the first time:D :xmas:
    Thanks Again
    Burt
  5. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    They're a 9/16 grade 5 so 80 ft-lb or so will work just fine. This is pretty darn tight with hand tools in that space.
