Torque specs????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Esteban86K5, Apr 26, 2001.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    So I'm in the process of putting a Detroit in my 14 bolt and I have a few torque questions. Basically I need the torque specs on all the bolts inside the diff. The bolts that hold the carrier together(I think it's like 12 or 14 bolts there),The bolts that hold the bearings in, the bolts that keep the holding pins in and the cover bolts. Also is there any easy way of taking the carrier apart without an impact wrench. I didn't want to bother my neighbor but if I'm going to damage anything I guess I'll have to.
    Thanks In Advance(Or like Mike aka Blazen91 says TIA, sounds kinda queer to me:))J/K Mike
    <font color=blue>Esteban</font color=blue>
    <font color=red>SEMPER FI TO MY BLAZER
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I thought my books were in the back but they're not, if they're at home i'll post when i get there, i seems to remember them not being as high as you might think, like 80-90 for hte carrier and around 100 for the bearing caps, but dont take that as the gosple. I got my carrier apart fairly easily, i put it in the vise (smooth jaws) put a wrench on the bolts and rapped it with a deadblow, imact wrench at the most basic level.
    RaisedK5
    "Friends don't let friends drive Fords"
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    The bolts that hold the ring gear and two piece carrier are torqued at 120 ft. lbs.
    The differential bearing caps are torqued at 135 ft. lbs.
    The differential bearing adjusting locks (holding pins) are torqued to 20 ft. lbs.
    The cover bolts are torqued at 30 ft. lbs.
    I did a complete rebuild on a 14FF for BlazzinOr with a Detroit Locker installed.
    I am currently doing a complete rebuild for Blazn86, also with a Detroit Locker.
  4. Esteban86K5
    3,712
    Bakersfield, CA
    That's exactly wat I needed, Thank You very much.
