Torquer 383 and a stock 700r4
Discussion in 'The Garage' started by Dain Fraser, Nov 21, 2005.
  1. Dain Fraser
    Dain Fraser Registered Member
    Jun 30, 2005
    32
    Canada
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Good torque converter and BIGGEST tranny cooler you can fit. :waytogo:
  3. Dain Fraser
    Jun 30, 2005
    32
    Canada
    Excellent (rubs hands together)
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    for the $4000 US pricetag, you can probably build an engine with some better components, and still have money left over for other mods (torque converter and tranny cooler :deal: )
  5. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Get a used 350 block, some decent heads (scoggin dickey's got some good ones for a fair price), cam+tappets, 383 kit (crank, pistons, etc), and intake, all plus machine work should be about $3 grand for a bad ass 383.
  6. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    I ended up spending $3000+ when I built my 383. Or 388 rather, its now been bored .060 and is a 2 bolt main. Thats a 4 bolt main ALL NEW. And its a roller!! He can rebuild it 2 maybe 3 times, And when he does he can pump it up to 500 HP if he wants. I like how it makes over 400 pounds torque from 2500-4000RPM. And peak HP is at 4500. With a redline of 5000RPM and 9:1 compression. Me lilkey!! :woot:
  7. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    My build up has a 2800 dollar stroker, but I didnt have to pay for heads or block, but Im gonna be running a fairly stock 700 r4 with only an upgraded sunshell and shift kit, so we will see how it fares.
  8. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Let me guess, "sunshell" another slang term for torque converter? I think I can see why.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    no, a sunshell is an internal part. part of the planetary gear set i do believe.
  10. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    No, the sunshell is a big, well.... shell. I has most if not all of the clutchplates in it and carries the load of the engine.
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    a run of the mill 3.75" stroke / 4.030" bore 5.7" rod 383, with 28cc valve relieve pistons, .015" deck, .025" head gasket and a set of Vortec heads (box stock) with an XE256 in it will do nearly the same, for probably pretty close to half the price. if you build it right, you wont need to build it 2 maybe 3 times.
    according to desktop dyno, this one makes 400+ ft/lb from 2000-4500 (2000 is the lowest it will go) and 322 hp at 4500 rpms. with a little detail work during assembly, it is highly likely to surpass those numbers without changing any parts.
