torquie exhaust
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aaaaggh, Aug 9, 2001.
  1. aaaaggh
    aaaaggh 1/2 ton status
    May 4, 2001
    161
    birmingham alabama cause there no ham like birming
    ok im ready to drop in my engine but im not sure what do do about exhaust. the engine is making about 330 hp and just over 400 ft lb. that of course is only at the block. what kind of exhaust does everyone like for high torque. i want it to sound ok but torque is much more impoortant than sound. ill have to use stock manifolds for my application since headers that will fit will be way too expensive.
    friends romans countrymen, lend me some parts
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    2.5" duals with Flows and a x-over pipe??
    Mike
    <font color=green>"It's like a sore dick deal, You cant beat it!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  3. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    A single 2-2.5 in pipe will generally create more torque than 2.5 duals. I am not to sure why that is, I would have to study up on it again. But I think it has something to do with back pressure. 2.5 duals is good for a high rpm motor, but it will hurt the low end torque. If you insist on having duals, keep the diameter of the pipe to a min. and use the cross over pipe.
    Keep it simple!
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    yea, but I think this also depends on how much HP your running etc. I'm sure there are others that can explain that. (and maybe I'm crazy too [​IMG])
    <font color=blue> Jeff - may the force be with you</font color=blue>
  5. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I'd go 3" single. I think the single helps the scavenging at low rpm.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Go with the 2.5" duals with crossover. That motor needs to breathe. Get headers too (1 1/2" primary, for torque).
    If you insist on small pipe, you can get 2 1/4. I've got a 250/330 hp/tq. motor and I use 2 1/4". DD2000 says my torque peak is 3000 RPM.
    If you insist on a single exhaust, a 3" will probably be enough. I'd still rather have the duals, with crossover.
    Tim
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I personally recomend 2 1/4" exhaust w/ a crosover or X pipe for max torque... also would recomeend it being off Thorley headers. Backpressure is a big part of having torque...gotta have th right amount... not too much... not too little
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  8. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Doesn't much matter with the stock manifolds, since the stock manifolds will be the restriction in the sys.
    Twiztid
    This is all about opinions, and this is mine. (if applicible)
  9. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    "I'd still rather have the duals, with crossover."
    Why?
    Pete
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The tuned part of your exhaust system doesn't go very far anyway. After about the first 50" I'm told the more restriction you can reduce, the better. However, if you run too big of pipe, it will cool too much, lose velocity, and then you'll start loosing power.
    I'd rather have the true duals becuase they sound FAR better and will still allow good scavenging--and reduce backpressure.
    The headers/manifolds and some of the pipe produce all the backpressure you could possibly want. After that's just restriction. Obviously you've got to get the fumes away from the passenger compartment, so you should really run a full exhaust on a K5.
    I wouldn't put single exhaust on anything around here. We don't have emissions so we have our choice.
    Dynomax makes a great kit for dual exhaust. I have the header duals. http://mavericktim.freeyellow.com/exhaust.jpg&gt; Here is a picture so you can see how it routes. It has side exit pipes behind the rear wheels and is quite cheap compared to muffler shops. I know, I don't have a crossover yet. I'm working on that, I just haven't got around to ordering that kit yet. I want one.
    Edit:
    I have a K10 shortbox, not a K5. For a K5, you just remove the extension pipes that go directly behind the mufflers on mine and run the tailpipe straight to the muffer and it'd fit perfectly. It took me about 60 minutes to install the pipes after the headers were done.
    Tim
    '84 Chevy K10, lifted, loud, fast, and 3/4 ton axles&lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by 84_Chevy_K10 on 08/10/01 01:17 AM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;
  11. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    "The headers/manifolds and some of the pipe produce all the backpressure you could possibly want. After that's just restriction."
    So, if I run manifolds with a couple feet of straight pipe, say dumping under my feet, I should get lots of torque?
    "Obviously you've got to get the fumes away from the passenger compartment, so you should really run a full exhaust on a K5."
    Agreed.
    "I wouldn't put single exhaust on anything around here. We don't have emissions so we have our choice."
    I have my choice as well, I have a waiver from the state saying I can legally run duals on my truck. I choose not too.
    Pete
  12. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I saw an add for a dual exhaust you could mail order, they were 150.00. Anyone remember seeing this or what company it was?
    thx
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  13. WOODYJ
    WOODYJ 1/2 ton status
    May 5, 2000
    144
    I am running the Thorley stainless torque headers and then just a run of the mill dual system. I will say this for the Thorley headers--they produce torque!!! I do have problems with them burning my spark plug wires now and then. Also it is almost impossible to change spark plugs!! If I had it to do over, I would not use the Thorley headers and stick with the stock manifolds. Much easier to work on, saves thousands of "Truck Driver Words", and doesn't take so much spark plug wire.
    k5woody I Don't Understand The Jeep Thing Either!!!
  14. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    If you can't afford the Thorley's, you could get a set of Flowtech Afterburners. That's what I'm using now and my torque did come up. I can't say it was a lot, but I currently only have the stock 350 engine.
    I think that if your engine has an appropriate cam, you won't lose that much torque with a large exhaust. A slightly restricted exhaust prevents the fresh fuel charge from escaping during valve overlap, but unless you have a radical one, the cam prevents that by allowing less exhaust time. Too much restriction will hurt anyway since it takes more power to move the gases out. It's your choice anyway, so pick one of the following exhaust areas:
    Single 2.25" = 3.53 sq. In. (I think this is what came stock)
    Single 2.5" = 4.91 sq. in.
    Single 3" = 7.07 sq. in.
    Dual 2.25" = 7.06 sq. in.
    Dual 2.5" = 9.82 sq. in.
    Dual 3" = 14.14 sq. in.
    I currently have Dual 2.5" with an H-pipe and a pair of Flowmasters. It sounds nice. Although I'm not sure, it will have to work with the 454 since I have no $$$ for replacing the system right now.
    Good luck and let us know what you decide.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I can't believe you CAN run dual exhaust, yet you don't. To me that's silly. I guess it must have been cheaper to run a single.
    &gt;&gt;&gt;So, if I run manifolds with a couple feet of straight pipe, say dumping under my feet, I should get lots of torque? &lt;&lt;&lt;
    Absolutely, if you use the correct size headers and pipe to match your engine. If everything is matched correctly, it works best, period. Theoretically the best exhaust system is one with the least restriction. So, the right size system that was extrememly short would be best.
    I don't like how you said, "I should get lots of torque". That depends on an awful lot of things. Exhaust systems aren't going to make a major change in the torque curve of your motor. You can either use an exhaust to take advantage of what your motor has to offer, (hopefully exhaust is set up for peak torque RPM of the motor to be at about the same that the exhaust is tuned for) or you can choke it until it makes drastically less power, but usually any aftermarket or custom exhaust will fall somewhere between those two extremes.
    I've made many exhaust systems. I know that mine works very well with my setup, and although I'd love to have bigger pipe for sound purposes, I am keeping my 2 1/4" pipe for torque, so it can match the carb, intake, cam, heads, and header primary tube size.
    Tim
