Torsion bar removal, how?
Discussion in 'The Garage' started by sled_dog, Jul 3, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I simply don't know what I'm doing with a Torsion bar suspension. So what should I do to remove these things? I cut one of them now, took so long I guess I might as well do it the right way. I removed the bolts to let pressure off then I have no idea what to do. Should I unbolt the torsion bar X-member and try to slide them back out of the control arms? This is on my 85 S10.
  2. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    I think there is an adjuster at the crossmember. If you let the tire droop to maximum and release the tension you should be able to get them out. You might need to remove that crossmember first though.
    I had an 89 S-dime about 10 years ago. had to replace the crossmember mounts and at one time cranked my bars so i could clear 31's...:crazy:
    Rene
  3. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Be Careful
    Heres a link over on FullSizeChevy, should be similar in principle Id thinkTorsion Bar Bible
    Id be careful, Ive heard some stories, torsion bars arent anything to be careless around..
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Eh, the one I cut through didn't spring at all(I had it chained and sayed out of any path it may take just in case). It drooped down under its own weight. With the bolts for the adjusters removed it seemed to almost completely remove the spring force. I still won't be careless about it, springs aren't anything to mess with.
  5. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    two big tools needed after bolt is loosened for tension. tool 1 is BFH and tool 2 is BIG long punch. thay rust in there pockets. need to drive them out. some come out easy to the front and some come out easy to the rear. some need tool 3 HEAT to go along with tools 1 and 2. good luck.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah, I got all the tension off(removed the bolt retainer with a gear puller), but they are just not budging. Hit them with a little PB Blaster and let them sit, I'll take a shot in the morning.
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Heres the correct way to do it. Theres a special tool, but I didnt have one so I took a big C clamp, one that had the flat swivel piece off of it so it was just a ball end. Then go under the truck, in the torsion key you can see an indent, put the ball end of the c clamp in the key and the other end around the crossmember and tighten up the key, putting tenion on it, then take the piece that is in the crossmember out (the one the bolt screws through) and then take the pressure off the key. The keys should fall down and you should slide the t bar out (and if it wont come like you said, hit it harder).
