torsion bar removal
Discussion in '1983-2005 S-Series models' started by Confederate9, Jun 2, 2002.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    on a 99 s10 blazer, how do i remove the Torsion bar compleatly?
    im doin a lift and i can seem to get it off!!! its drivin me crazy
    thanks
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    This is another one of those cases where you need the right tool. It allows you to take all the stress off of the torsion bar so that it can be removed. /forums/images/icons/frown.gif I'm surprised that the instructions for the lift kit don't show it and explain it. /forums/images/icons/mad.gif Maybe you can rent one from a parts store. Just tell them that you need to remove a torsion bar and need the right tool.
  3. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    well i took off the controll arm already so there is no stress on it
  4. stump
    stump Registered Member
    Aug 3, 2001
    51
    Central Texas
    Are you asking how to slide the torsion bar out of the control arm? If so, just bang the holy-hell out of it. It may take a sledge hammer and some determination, but it will eventually come out. /forums/images/icons/smile.gif A heating torch or lubricant may help. Good luck.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Are you going to replace the torsion bars or reuse them? If you are going to reuse them don't scratch up the small diameter surface of the bar. Also make sure they go back in exactly the same way they came out.
