Total Newbie Question
Discussion in 'The Garage' started by WY_75, Jan 31, 2006.
  1. WY_75
    WY_75 Registered Member
    Dec 27, 2005
    15
    Cody, Wyoming
    I have done a couple of searches and am still wondering:
    What lubricant does a NP 205 need? Gear lube?
    I know a 208 needs a lighter fluid like 10W-40 or ATF.
    Thanks for the help.
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    80/90 weight
  3. WY_75
    Dec 27, 2005
    15
    Cody, Wyoming
    Thanks Sir. I thought thats what I needed, but didn't want to make a dumb mistake.
  4. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Hey Man,
    Just so you know, I think I asked the exact same question a month ago. I can't know what I don't know.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    gear oil is fine, i also think atf is ok. i remember someone mentioning that for the newer ones atf is recomended. not sure about that but i know gearoil works great
  6. goldwing2000
    goldwing2000 Guest
    AFAIK, ATF in an NP205 is a big no-no. It's nowhere thick enough.
  7. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I'd only use gear oil, 80/90.
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    like i said i wasnt sure, it may have been the 203 case that it was recommended for (basically the same thing as a 205, at least the reduction box) but i do remember a post where this was recommened. not saying i would run it though.
  9. 79k20350
    Nov 22, 2004
    7,757
    Ct
  10. WY_75
    Dec 27, 2005
    15
    Cody, Wyoming
    Thanks for all the help guys. I think I will stick with 80/90 gear lube.
  11. goldwing2000
    goldwing2000 Guest
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    i never said id run it, just that it had been mentioned that atf could be used. i never said there was any evidance that it would work fine. if you look at that post i recommended 80/90 gear oil. thats what id run cause i know 100% it would work
  13. goldwing2000
    goldwing2000 Guest
    Yeah... I got that. Just saying that it has no bearing on your sanity. :D
  14. 79k20350
    Nov 22, 2004
    7,757
    Ct
    well really are any of us sane? come on we dump thousands into trucks that cost us maybe 2. how sane is that?:D sanity is all perspective. its the ones who think their sane that you should be scared of:D
  15. goldwing2000
    goldwing2000 Guest
    Damn right! Preach it, brother! :bow:
  16. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    Hey there. I am in Powell... actually live just on the Cody side of Ralston. If you need any help give me a shout.
