totally frustrated - can't figure out why I can't get spark...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, May 4, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    totally frustrated - can\'t figure out why I can\'t get spark...
    ok guys...
    I have no idea how these two are related, but they seem to be.
    I have the custom VDO gauge cluster in my 89 k5 right. well there are a few things I have never hooked up, and wanted to get taken care of. I have never had my caution light hooked up, and my bright / dim indicator.
    well the other night I was coming home from fishing, and I blew a fuse which killed my gauge lights. well I temp hooked it up with the power cable to my gauges so that when the ignition came on the dash lights would come on too.
    well I disconnected everything to fix all this, and disconnected my parking brake indicator, and 4x4 indicator permanently. well I got everything fixed, and I connected up all the gauges to test everything (blinkers, bright/dim, all gauges etc.). everything seemed to test out fine.
    well everything was fine until I went to start the beast, and for some reason I can't get spark. what in the world would keep a TBI from getting spark? I'm not even sure where to begin.
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    Re: totally frustrated - can\'t figure out why I can\'t get spark...
    one thing comes to mind, if your gauge cluster has a tach in it, the tach signal wire is connected to the ignition circuit. check to be sure something didn't get disconnected or grounded out to kill the spark.
  3. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    when you turn on the key the ignition switch sends the power to the coil. do you have power at the coil? if not it must be in the wires you unhooked to fix your gauges. if something is grounding out, you could try removing all the non essential fuses and then try cranking.
    electrical trob shooting is never fun
    keep us posted
    good luck
    chris
  4. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea it does - but I already double checked that. I'm assuming the spark is controlled by the computer. this strange part is that all the gauges have 2 senders in the vehicle; one for the computer, and one for the instrument cluster.
    I've ran this vehicle with no gauges in it, and nothing hook up. I got the wiring diagrams outta the hayes manual, and looked up all the wires in the area I had dealth with, and I cannot find the problem anywhere.
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    do you happen to know what color of wire goes from the ignition to the coil?
  6. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    no, but you can look at the coil and i think there are only 2-3 wires there, i think a white wire is the tach hookup, but dont quote me on that. just look at the coil and trace teh wires from there back
    chris
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    thanks for the F.Y.I ... I'll take it up in the morning, and see if I can get this figured out.
  8. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Did your truck ever have an alarm in it? I blew a relay out in the remainders of an alarm that was there from a previous owner. I just found it by starting at the key with a volt meter and working my way out untill I lost voltage. I think my back still hurts from being under that dash for so long. Took me about an hour from the time i started looking to the time I was done.
    If you think it is a computer problem, disconnect the battery for a few minutes and then try it again. If the computer isnt screwed it will reset itself and work again.
    Ryan
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If you have power to your coil but don't have any spark then you seem to have a bad ignition module in the distributor. Replace the module and it should fix it. By the way, it is a good thing to keep a spare in the glove box as this is a common problem with GM vehicles.
  10. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    well guys - I am more frustrated then ever.
    there is spark coming from the ignition, but there is a white wire, and a red wire that connected into coil. one is getting power, and the other isn't. there doesn't seem to be any spark coming from the coil.
    when I put this new engine in I put a MSD blaster coil II in this so I'm going to try the old coil as my next move. I don't believe that is going to do anything though.
    I'm still betting that there is a computer wire somewhere that isn't getting activated correctly, but I'm not sure exactly where & how to find that.
    anybody have any new suggestions?
  11. Sparky
    Aug 20, 2000
    423
    If you are getting power to the coil, its probably the ignition module. If you take the cap and roter off there will be a couple of screws holding down the piece that has the three wires coming out of the distributor. Take those off and out comes the ignition module as well as the capacitor. Just pull the two pieces apart (they will be connected with male and female wire connectors) Take the piece without any wires hanging on it (ignition module) to the parts store and have them test it. They just plug it into a little machine and tell you if its good or bad.
    Ryan
  12. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    already changed the ingition module...
    got the problem fixed though, and I was 100% wrong!!! it was the coil.
    go figure I have 700 miles on a new MDS blaster II coil, and it is bad! /forums/images/icons/mad.gif I don't know what the warrantee is on these, if there is one, but I think it's going to get replaced with and accell. I know a lot of people don't like accell, but hey I ran one before, and I liked it a lot. the MSD coil's reliability wasn't real great! /forums/images/icons/mad.gif/forums/images/icons/crazy.gif
  13. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Last Friday I saw on this board to NOT use the Blaster 2 coil from MSD. They had the same early failure problems. They suggested using the MSD SS Coil instead.
