Toughness of 208's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Sep 12, 2001.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Toughness of 208\'s?
    If you bottom out on some rough dirt/rock would it damage your 208 pretty bad? If not how much can a 208 take?
    How do you make skid plates for your transfew case.. and how do you mount them.
    6in 87' K5 w/ 35" BFG muds.
    Kn filter
    What I need: 4.11 gears, Lim Slip Dif, Force2 Catback, rear springs , Throtle body spacer.
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Re: Toughness of 208\'s?
    If you bottom out to hard you make crack the case or even knock a hole in it.My 82 has a factory skid plate that bolts to the cross member and so does my friends 88 so you may find one in a salvage yard or the dealer since it was a factory option.
    A BIG HAMMER CAN FIX ANYTHING.. [​IMG]
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I also have the factory skidplate on mine and haven't had a problem. If you are handy at fabricating, then you could make you own and either mount it to the t-case crossmemeber or the frame...
    Mike
    <font color=green>"My K5 is purdyr than your sister!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I also have the factory skid plate. I have landed on it pretty hard, dragged it across rocks, and let my buddy drive once and got it high centered on the skid plate. So far no problems. I has a few dings in it though.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
