Tourque spec help?
Discussion in 'The Garage' started by highrlr, Jan 13, 2005.
  1. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    I am in the process of installing a 4inch shackle flip and front springs in my '89 GMC jimmy and was wondering if anyone had the tourque specs for the ubolts, spring eyes and front and rear shackes? Thanks for any help.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    If I remember right the u bolts on a 1/2 ton are 85lb/ft, the sway bar eye bolts are 90lb/ft. Don't remember the shackle ones.:confused:
  3. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Thanks for those ones, anyone know the shackle bolt torque ratings? Or some tips on where I could find them?
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    40-45 ft/lbs
  5. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Oh and im also replacing the steering arm so how about the specs for the three bolts that hold it on and for the nut that holds the pitman (?) arm to it? And does anyone have any tips as fas as removing the steernig arm, las time I did one I remember it was a real struggle to get it off:mad:
  6. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Thanks Cegusman!:grin:
  7. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Read this to get the arm off.
    Steering arm removal
  8. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I think my U-bolts are around 130ft. lbs :D
  9. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Thanks for the link Cegusman, lots of good tips on there. Damn Big pappa that sounds like a lot of torque for u-bolts!
  10. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I like things BIG :D
    BIG motor = 454
    BIG tires = 39.5"
    BIG axles = D60 & 14B FF
    BIG U-bolts (5/8th") = BIG torque
    :haha: :haha: :haha:
  11. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I remembered wrongly...sorry! My '78 book says 120lb/ft and my '91 book says 150lb/ft.
    I should have remembered as I only did it a few months ago. Sorry!
