tow hooks?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Marshall, Jan 21, 2003.
  1. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    Does anyone have a picture of how there tow hooks are mounted. i think mine might be mounted backwards.Please let me know how you have mounted yours.
  2. K5Kell
    K5Kell Guest
    Backwards? Does that mean that the open end faces out? if so just spin them around, shouldnt be to hard to fix.
    -Kell-
  3. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    You have to mount them backwards on a Chevy/GMC, cause they make so much h.p. that you have to slow them down some way. /forums/images/graemlins/grin.gif
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The open end should be towards the rear if that helps.
  5. dyeager535
    26,975
    Open ends towards the rear as you said, with the actual hooks facing inward toward the center of the frame as I recall.
  6. Marshall
    Apr 8, 2002
    204
    LiveRmore,CA
    so the tip of the hooks faces inward......i have em on opposite of that. the tip faces toward the outside of the truck.
  7. dremu
    Feb 27, 2000
    15,954
    444
    East of San Francisco
    Look at page 6 of the brochure for the 1976 Chevy Suburban on
    Brochures Pages
    (direct link: 76 Burb page 6 )
    I know it's a Burb, but my '74 Blazer was just like this 'fore I changed bumpers.
    This is the old-style J-shaped hook, but you can see at the bottom (passenger side) that the hook points back.
    Now your truck looks newer -- anybody know when they changed? 73-80 and 81-91? I know my '90 Burb has the newer style hooks, that are weirdly S-shaped.
    Page 6 of the 1986 Jimmy brochure has a crappy picture here
    86 Jimmy p6 where you can see the vertical slots in the fender skirt on the front, which have the tow hooks, and they also point backwards (hook going towards the rear.)
    I remember when I put the nose guard on the Burb, those hooks are a bear to line up cuz they twist around so funny.
    HTH.
    -- A
  8. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    best pic I have of how the tow hooks face inwards
  9. Marshall
    Apr 8, 2002
    204
    LiveRmore,CA
    jeeez.....mine are on wrong thanks for the hel guys. I will switch em around tommorow /forums/images/graemlins/rotfl.gif.
    Thanks, Marshall
    350/TBI/3.73 Gov-Lock/208/31"S
  10. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    what are yall mounting the tow hooks to i got a set from autozone and i cant find a place to mount them except sidewards
  11. dyeager535
    26,975
    Umm, the factory holes?
    The '81 ups (at least) mount the hooks with two large bolts that are offset on the frame. Aftermarket hooks probably require you to drill holes.
  12. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    The factory holes go all the way back to 1975. My 1975 didn't have the hooks, so I took some off a 1978, and they fit perfectly. You should have the holes if you can find the factory hooks. I see them on Ebay all the time.
    Good luck.
    ________________________
  13. dyeager535
    26,975
    I don't think the older factory hooks interchange. 'Course I could be wrong, since I don't own a '75, but I recall hearing the way they mount being different.
    On the '78 hooks, were the bolts "vertical", or was the portion of the hook that mounts to the frame "bent" at a 45* angle, so the bolt holes were staggered?
    Could have been I've just seen aftermarket hooks and thought they were old style ones too.
  14. dremu
    Feb 27, 2000
    15,954
    444
    Re: tow hooks? Two styles
    Which I'll *guess* are 1973ish-1980, and 1981+.
    At the very least, the 1987+ models use the goofy S-shaped thing Dorian talked about, and the pre-1980 models use the straight J-shaped ones. (My '74 had them factory, btw.)
  15. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    mine only go on one hole. they mount to the body mount support i believe. but only one bolt holds them in- and whenever i pull someone out they bend up into my bumper, and frankly i'm scared they are going to break off or bend up to far anyone have a close up of where to mount them?
    note- mine are HOOKS [​IMG]
  16. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    they need to be mounted w/ at least 2 bolts, fix it before you hurt someone
  17. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i know, but there ain't nowhere to put two bolts in. trust me i've looked. and my drill won't drill through the sideplates of my pushbar, which is plenty strong, if it did they'd be mounted horizontally on it in an instant. Most of the time i'll just wrap the chain around the pushbar, or use the extra hitch ball storing holes on my receiver.
  18. schmuck
    Nov 11, 2002
    523
    could someone post pics of their factory tow hooks or aftermarket that works right
  19. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    [ front hooks looks.
    Thats not a pic of how they mount, but how they look. And for the back of the truck over my receiver i put two of the hooks pic'd above on the bumper on that extremely thick piece of metal that a ball mount would go onto. Ill try to get a pic of it up, and if you want me to a pic of how my factory front hooks mount up.
  20. Marshall
    Apr 8, 2002
    204
    LiveRmore,CA
