Tow points on front with stock bumper?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 70~K5, Jun 1, 2002.
  1. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    What have you done for tow points when running stock front bumper?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    At the moment I wrap a tow strap around the front spring hangers /forums/images/icons/frown.gif I don't really want to drill holes in the frame right now because I will be putting on a front tube bumper sometime and don't want to have the frame horn look like swiss cheese.
    You can use 2nd gen tow hooks...the ones that point down.
  3. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    I purchased the tow hooks with spring retainer and bolted them on the frame rail under my bumper. Here are some pictures.
    http://community.webshots.com/photo/26977104/33144116cuQIGi
    Evan
  4. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    I put a piece of 1/2" x 4" steel plate between the frame rails and bolted the hooks to it. I drilled out one of the spring hanger rivets for a 3/8" bolt and put a 5/8" bolt in a hole that was all ready in the frame in between to the spring hanger rivets. I also welded a chain link to it and bolted a chain to my hood latch so I can chain my hood shut. I'll see If I can get some pics.
  5. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    I have some pics. I can email them to you.
  6. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    A couple of pieces of 1/2 inch steel bolted to the frame hanging just below the bumper with clevis attatchments - hardly realize they're there
  7. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    I've got a 2" hidden hitch installed up front...found me a tow hook that slides into the receiver and *voila*
