Tow question
Discussion in 'Tow & Trailer' started by CK5, Apr 19, 2004.
  1. CK5
    May 19, 1999
    21,623
    701
    CO
    OK, almost forgot about this, the last time I towed (98 3/4 ton Burb 454) my check engine light came on but I noticed nothing, everything reading normal etc. and it went out about 50 miles after I stoped towing and hasn't been on since, I wonder what it was?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Prolly a load on a weak sensor that isn't dead yet but will be needing replacement soon. I had this happen to a buddies 96 silverado truck. 3 months later 2 sensors were dead. So i'd just keep a watch on it and check for codes every once in a while.
  3. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    You will have a code stored, I'm going to roll the dice and say it was O2 related. I would scan it and see. /forums/images/graemlins/thumb.gif
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    When you tow it puts extra load on the engine of course which requires more fuel. The two sensors that give you the grief there will be the O2 sensor and the knock sensor.
    John
  5. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Check the codes.
    I started to get a Lean code when I was pulling under load and it turned out to be my fuel filter
  6. CK5
    May 19, 1999
    21,623
    701
    CO
    Well no codes, weird.
  7. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    We have a Chevy work van and sometimes after hauling on a hot day the oil seems to get thin enough to where at idle the oil pressure drops and trips the light. Do you have an oil pressure gauge?
  8. CK5
    May 19, 1999
    21,623
    701
    CO
    Yep, didn't notice anything out of the norm that day. /forums/images/graemlins/dunno.gif
