tow straps, tow hooks
Discussion in 'The Garage' started by 78Suburban, Nov 21, 2005.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I noticed a 4 wheel parts ad in my last issue of petersons (subscription ran out, not gonna renew, gonna get a ck5 membership instead)......... anyway, I noticed a reciever hitch tow hooks for 10 bucks, and the reciever hitch shackle was more expensive........ would the cheaper tow hook be strong enough? I noticed 2" tow straps (20k lbs) and 3" tow straps (30k lbs)... which would I be better off getting?
    anything else yall can think of that I would need for recovery by another truck (I don't have the budget for a winch).
    All of this is for towing a HEAVY stock burb with a 14ff boat anchor out back and only 33" tires.................. BURIED in the mud..
    thanks,
    James :bow: :bow: :bow: :bow:
  2. Kamots
    Kamots Registered Member
    Oct 9, 2002
    47
    Oklahoma
    A highlift jack! Use it as a winch, takes a while to get anywhere but you can do it. You can also use a highlift jack to move you offa the highcenter or rock or tree your stuck against. And if your going places where no other vehicles or anything to tie off to, you get a pullpal. Pullpal is basically an anchor you put in ground upstream of your vehicle and tie off too. Works great.
    I dont like anything cheap when it comes to straps and hooks. Heavier the better. I've seen and heard of too many injuries and deaths due to cheap and faulty equipment (not to mention the misuse of equipment).
    Kamots
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    get the reciever shackle, tow hooks let straps come off and can straighten out or break, IMO for a burb it is a waste of time to try and pull one out with anything less than a 3" strap
  4. BudTX
    BudTX Registered Member
    Oct 4, 2005
    36
    Kansas
    I'd get at minimum a 3" strap for a heavy vehicle like a Suburban.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Agreed.... minimum 3" Typically the bigger the better. They are not cheap for the good ones, but how much is your life or body worth??
  6. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    how would I attach a 3" strap to a reciever shackle? is it small enough to loop through?
    Should I go ahead and get something bigger?
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You would use a the shackle , unscrew the pin , put the shackle through strap eye , and screw the shackle back to its mount .
  8. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    shame im all out... (except for the one im keeping)... I was selling 1 3/4" wide tow straps that will fit into the receiver and you can use the pin to attach it..... 40' 4 ply rated at 47k..... $40 plus shipping..... usually less than $50.... people that have bought them LOVE EM....
    http://coloradok5.com/forums/showthread.php?t=127154
  9. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Where did you get them.. there are a bunch of army surplus store around here, would it be worth looking there?
  10. RootBreaker
    Nov 29, 2001
    5,118
    173
    yeah id look there... :wink1:
  11. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    Can sopmeone post up a picture of what you are talking about as well as how to use a highlift as a winch?
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
